I've seen some cars with, some without, should there be one in the line from the source to the booster?
there should be a check valve at the booster where vacuum source enters. if you can see i posted pic on engine side of master cylinder there is faded yellowish circular valve as main source goes inI've seen some cars with, some without, should there be one in the line from the source to the booster?
that nipple on the booster is a check valve itself?there should be a check valve at the booster where vacuum source enters. if you can see i posted pic on engine side of master cylinder there is faded yellowish circular valve as main source goes in View attachment 89300
nope its a check valve. ive since added a secondary canister that also has check valve on the entry just in case of emergencythat nipple on the booster is a check valve itself?
thought that was just, y'know, an entry.
yup that is a filter, surprisingly no check valve in thatMy 85 has some sort of canister in the line between the manifold and booster. I assumed it was the check valve.....
