Chevy 305 in an american cutlass?
Marinizzle
14
2
Ontario
Probably a stupid question.
Did american Cutlasses (1987) ever come with the chevy 305 factory?
i'm trying to run a vin and it's a little rusty, but the only way the vin in verified (Check code verified vin was ok) says the car was built in pontiac michigan, assembled in the US but has a 305 chevy. (I'm in canada btw).
I heard from a lot of sources that the 87 canadian cutlasses ONLY came with 305's, americans had the 307 or 231... Can anyone help?
Thanks
78chevolds
126
50
They came with the Oldsmobile 307. Simple check, is there an oil filler tube behind the water pump? If so, it is an Oldsmobile engine.
ck80
Moderator
Moderator
5,743
9,121
Thanks
If the car was built in an American plant FOR EXPORT to Canada, then yes, it would have a 305.
ssn696
Living in the Past
5,546
6,671
Permanent Temporary
Check the 8th digit of the VIN. If it is ‘H’ that was a factory 305. Look under the trunk lid for the RPO tag. Should have the VIN on it as well. Or the door jamb.
hangar401
One Owner
Oct 3, 2019
129
141
Windsor,Ontario,Canada
Thanks
My 79 built at St.Therese plant has the 305
8,823
7,775
Melville,Saskatchewan
I am thinking it was an American built car for the Canadian market. Every 87 I have seen were sbc 305 with a 2004R, talking Canadian cars.
