305
The most misunderstood engine in the Chevy small block family. Just check any forum, when the subject of building a 305 is presented, the reply is almost ALWAYS "build a 350" Heres my take on that, DONE, I GET IT, by using the "bigger is better" logic, we all must build a Hemi. Now lets move on to the 305. I've done a LOT of research and the result is as follows.
First to produce 400HP in a V8 you need to move 500+ CFM @ 100VE. Thats all. In stock form a 305 moves 431 CFM @ 6000 (assumed VE = 80) If we modify the intake/heads/exhaust to get as close as we can to 100 VE and bore it .020 over (now cid = 311) we will move around 539. @ 6000
With 1 hp for every 1.3 cfm, we have a potential of 414hp
The following combination, properly prepared, will do just that
1989 LB9 roller block .020 over 9.3cr
081 Heads, stock 1.84" valve flow 201.8 @ .40 lift with minor port work
Performer manifold
long tube headers, wraped
Stock LB9 cam Lift .415/.430 Duration 207/213 Sep 117 (non auto LB9 f body cam)
Dual roller chain
600 cfm carb
Performer manifold
Roller 1.5 rockers
HE ignition
Timing adjusted for 36 total advance (sb about 8-12 @ idle depending on the distributor set up)
I estimate the build will cost about $2,000 give or take, including machine costs.
I'll be building this engine next month and will post the step by step build, parts list with cost, and dyno results in late August.
