I'm working with a matched set of Chevy 041 heads that looks like an older rebuild. They have what looks like GM screw in studs (not set up for poly locks), double valve springs (exhaust with a blue stripe, intake with a red/orange stripe), & a rough measure of 1.94/1.50 of the valves. I would like to know what the rate is on the springs or if they are even OE/OE replacement. This is a challenge since there is no guide on how any are marked. The "back story" I was given was they came off a bone yard engine that was described as a 302 cause of the crank flange & pistons. Of course he got them in the late '80's/ early '90's, remembered those details but didn't know of the screw in studs. It would be cool if they were real DZ alt number heads rebuilt to spec, but the valves don't back it. Hope someone out there can help so I can figure out if I should use or replace the springs. To help, I am planning to run a cam like the Eldelbrock 2102.
