Yeah yeah yeah... You don't actually "build" a late model Harley, more like throw expensive accessories at it.
I bought the CVO specifically because of the power of the 110 engine, and it already had many of the upgrades I would've done on a standard Road Glide anyway, like heated seat/grips. I bought this one used in December '15 with just over 6k miles and the previous owner had already done a bunch of upgrades like Stage 2 Boom audio, air cleaner, tune, Vance & Hines exhaust, some extra chrome doo dads, some Willie G bling.
Now, where this "build" may actually be a build, is that H-D considers the CVO a "factory upgraded" bike so many other upgrades/accessories have the disclaimer "will not fit CVO" In hindsight I should've just bought a standard RG with the 103 engine & built from there. So, there will be some MacGyvering to make stuff work!
First up will be mini apes, then converting the Tour Pak to a quick detatch. Then a few other things. Gotta get creative on the audio stuff because with these newer Harleys if you upgrade to Stage 2 Boom audio speakers & amps it requires the head unit be reflashed by the dealer only. And once you have the flash, if you disconnect the rear speakers (as in, the speakers that are in the Tour Pak that I want to make quick detatch) then the whole damn stereo goes dead! So basically you can either have the upgraded stereo, or the quick detatch, but not both. UNLESS you spend almost $2k in parts to go to speakers in the lids... And since these newer Harleys are computer controlled on a CAN bus & the head unit is essentially the brain of the entire bike, they did a good job making the stereo upgradability pretty much proprietary, and the nearly non-existent aftermarket stereo stuff out there is more expensive than the Harley stuff.
Below are a few pics from back when I bought it.
