Chrome rocker panel accents
NRoman70
17
21
Hi all,
I have an 86 Cutlass Supreme that I bought a couple of days ago. It doesn't have any of the rocker panel chrome. I didn't think much of it at the time. I figured I'd look online and I'd have them no problem.....well I've learned that they are not easy to come by. I've been searching for Cutlass chrome pieces. I'd the chrome from a Regal or Monte compatible? Or at least a few of the pieces?
O. D. Showtime
3,007
3,528
Regina Sask. Canada
I believe alot if not all of the trim was held on with plastic clips that fit over small studs on the body. You'd have to acquire the clips and then figure out how to fasten them...maybe two sided tape?
Where are you located? I have access to this Cutlass with if I remember correctly almost all the pieces...
Not sure if you can see the screw bottom right of the right hand front trim holding it on (not factory) the other front trim is gone and there is a big piece of stainless stuck there.
565bbchevy
9,614
12,683
Michigan
That's because I keep removing and throwing the chrome away when I get a car.
NRoman70
17
21
I'm in Long Island. Nassau County, NY
TURNA
Rocket Powered Basset Hound
Jul 24, 2009
10,941
19,992
Socialist NY
