Hello,
I have a 79 El Camino with 350v8 (I attached a crappy photo of it since this is my first post and I know you might be interested). Previous owner (a friend so I trust he believes his claim) claims the AC was fixed but it sat for a while between that time and when I purchased it. Now that it is heating up here in AZ again I decided to fix the issue.
The air blows into the floor exclusively regardless of settings. The only thing that changes when I make changes to the control panel is fan speeds.
Vacuum is working under the hood and comes past the firewall. All actuators are working and the gates open when I apply vacuum to them but none of the gates open when using the control panel on the dash of the car with the car running. The middle gate that uses the blue line is the gate that needs to work to send air through my dash but like I said none of the gates are actually opening so obviously it is a problem. I did find a leak in the red heater line as shown in the picture which I have now patched. The issue is not resolved but I didn't expect that to be the issue since it was heater line.
The only thing I can think to try is cleaning up the HVAC control panel in the dash as it is quite dusty since I live in AZ and it also sat for a while. I am currently in that process now and if the issue is resolved from a good cleaning then I will let you know but until then I would love to hear your suggestions as I have run out of ideas.
It seems that vacuum must be lost from the time that it reaches the connection point behind the glovebox and the time the HVAC control panel sends the vacuum to the actuators since I know they work, their gates work, and I know there is vacuum behind the glovebox.
**If anyone knows where I can find new actuator nipple connection points and the clip that holds it to the actuator (the clear silicone thing that has a hole in it) I would really appreciate it as I would prefer to replace that if possible rather than just patching it. I don't even know the name of that part as you can tell so I can't search for it. Also that clip was missing on the car.**
Thanks
Thanks
