The AC compressor wires don't look too bad... What probably happened was the stock spade terminal connector rotted or melted away, which is very common, and someone went to Autozone and got one which is mainly used for an alternator (which explains the red and white wires). Then someone used a butt (haha, butt) connector to put them together. It's probably a good connection but they could of at least made an effort to hide the connector. If you ohm one wire with a solder connection, and one with a butt (haha, again) connector, I doubt you will see a difference on the DVOM.
I think I'd have to agree with Blake though. On something like this with an oddball (no offence to anyone on here) engine, there's really only certain things you can remove so that it just stays running right. It'd be a waste of time showing off your uncluttered V6 compared to a cluttered V6.
But I'm pretty sure you can just remove or hide all of the plugs that were on the carb now that you have an Edelbrock carb, besides the choke wire.
