The "ball" is a vacuum storage IIRC - that can go to.
DO NOT PUT an Small Block Chevy in your Olds!!!!! - put an LS1 in
LS1GN said:The "ball" is a vacuum storage IIRC - that can go to.
MPac said:By emission wires I ment to the smog pump and such. I don't butcher I really want to clean up my engine compartment and make it look nice before I drop my 350. I have cruise control on my cutty is that what the ball could be to?
I just removed the ECM harness on my 82 GP. Under the A/C box on the firewall the harness has a rubber boot that is screwed to the firewall. To get to it you have to remove the inner fenderwell. That is not easy, there are 3 bolts that are almost impossible to get to without removing the fender itself. What I did was remove the glovebox and the kickpanel. The computer is behind it. Unplug everything, remove the computer, and peel back the carpet. You will see the harness coming through the firewall. I used a utility knife and carefully cut the boot around the perimeter of the hole freeing it up. I carefully pulled the harness up through the engine compartment. Back inside I cut the 2 screws that held the boot with a dremel and cutoff wheel, fabed a sheet metal cover plate and covered the hole( I used 2 sheet metal screws and silicon gasket sealer. Thats as far as I got. Good luckOh lord my cutlass before I bought it was airbagged with 13 inch wire rims on it. Yeah I don't understand what the big deal is about the Chevy engine is. It's still GM it's not like I'm dropping a ford or dodge in it. I bet if I dropped a Hemi in everybody would love it.
Double V- I will try to get a picture of the line for you to show you what I'm talking about.
