Cloyes vs Milodon vs other timing chains
kustomkyle
646
47
Just wondering what everyone's preference is in terms of replacement timing chains?
I've been told to stick with Sealed Power or Cloyes, but I've been looking at Milodon as being a true roller design, holding up to many miles/abuse with no stretching.
Oct 14, 2008
8,823
7,775
Melville,Saskatchewan
Cloyes Billet, 9 way adjustable, very good for degreeing the cam, which should be done, even on a stock build. https://www.summitracing.com/parts/clo-9-3513x9/
I used the now discontinued Cloyes Street Roller last build, the chain fit sloppy and was only 3 way adjustable. I am glad they discontinued it.
84 W40
581
793
Cloyes, been using them for years with no issues on a stock to mild build. Street and track , true roller billet.
bracketchev1221
1,410
1,647
I use the cloyes billet race roller chains in my engines. They make them with 3 positions or 9.
kustomkyle
646
47
It doesn't seem like with Oldsmobiles there's any problems with additional chain width as opposed to other engines, like SBC's where you would need an aftermarket timing cover for clearance?
455'ed80Regal
467
211
Lincoln, MO
Cloyes gets my vote.
TURNA
Rocket Powered Basset Hound
Jul 24, 2009
10,941
19,992
Socialist NY
I used SEALED POWER's timing set part number CTS-1005
100% complete set chain both gears ALL gaskets/seals needed all for 24 buxx
Comes with Fel-Pro gaskets
100% MADE IN USA!!!!!!!!!
And just so you know Colyes makes the sets.
If you are doing that you should do the water pump as well since it is apart I highly suggest you get the
GMB High Performance Water Pump 130-1260P
If you do get this pump you MUST use Gates lower hose 21143
I found that Gates is the only one that makes the correct size inside diameter hose that correctly fits.
Other companys use the same part number for the same application but have the wrong size diameter.
Reactions: 4 users
