I had two clusters to work with and used the one with the best connections on the back board. I cleaned up all the connections squeezed all the pinch clips and added working bulbs with all connecting tabs bent up a little. I Put a wire across the tach v8 leads then swapped gauges till I had good tach yay. Good gas gage temp gage volts. BUT no oil pressure. Both clusters pegged the oil pressure to read full all the way to the right. Also when I put the lights on it freezes the tach needle in place that may be a broken trace on one of the light connection that has a bulb in it. I will try it with this bulb out next
