The HEI cap has the negative for the tach wire.
Ive got a seperate coil and a Mallory.
So if that goes to positive, what goes to the negative side and the distributor ? I guess you can tell Ive never done that wiring before. LOL
Pink? The old 6ALs that I knew were white for trigger, red 18ga. for ignition, and 10ga. red and black for battery with the tach output on the box.
Anyhow, if they're saying pink is the trigger, that will go to the negative coil out put from the module ('tach' terminal) on the HEI. Orange and black need to go directly into the coil. You can repurpose the factory plug, but you need to isolate the coil from the module while maintaining power to the module on the factory 12ga. pink.
There should be something in the destructions about gutting the module and using the purple & green to use the signal from the VR sensor in the base of the distributor. Personally, I feel this is better because you are eliminating the module completely and letting the 6AL perform all ignition duties.
*ignition power, yes.The pink wire for the distributor ????
Thats the 12 volt power to it
