So, I was perusing Umi's website and came across the QA-1 coil over set ups. Other than price, what are some pros/cons of such a system? Anybody have a coilover set up?
UMI Performance said:With a QA1 coil over kit you can save 10lbs of front end weight.
The single adjustable coil over kits feature 18 shock adjustments and height adjustment with spring rate choices.
Like mentioned the kits work nice for race applications but also work well on the street, many people select them just because of the ability to change front end height. The downfall is price, to get the spanner wrench and bearing kit you are around $500 for a kit.
What type of driving do you do with this car? Are you looking for a lowered look or just new springs?
GhettoRacingKid said:suspension is a science. most of it all comes down to what your doing, what you want to do and how your going to drive it.
