column loose
Cutty1
412
2
metro detroit
anyone on here make a sticky on how to get to the bolts and reloc tight them my steering column moves up and down and i turn and it very irritating
beermonkey9417
2,443
12
38
des plaines, il
under the steering column theres a plate held in by 4 screws, under there is a bracket that has 2 bolts that hold up the column. get some lock tight and tighten them up and youll be good. when i bought my elky 1 bolt was loose and the other was missing. so i was looking around on the floor and found the other bolt, or was it a nut, i cant remember ,but you get the jist...i tightened them down and now the column doesnt move around anymore. good luck!
jmt455
402
SE Michigan
Tilt columns loosen up and need to be serviced with Loc-Tite on the 4 screws that cause this condition.
Excellent write-up here: http://www.superchevy.com/tech/sucp_0707_tilt_steering_column/index.html
Most steering column repair places will charge $150 for this repair.
With a couple of hours (at the most!) and the proper tools, it will cost you less than $15 to BUY the pivot pin tool and some loc-tite.
Check around; many auto parts places will lend you the steering wheel puller/lock plate removal tool and the pivot pin pullers for FREE.
