I found a good trans shop in NJ (from a previous thread) and I'm on board for a new 700R4 trans swap. I have a column shifter. The basics like trans, TV, crossmember, drive shaft are all easy to pick out. Its all been done before. One thing I can't find is if there are any mods I can do to my speedometer so that I can properly set the needle into the proper gear. My current set up does not have overdrive so I have P,R,D,2,1.
Is there a mod or speedo from another car I can swap so that when I get the new trans the needle will point to the right gear? It would bother me to have the needle pointed to D when in overdrive etc.
