Column swap question
Baker7888
567
97
Maine
Forgive me if this has been addressed before. I swapped my th350 with column shift for a t10. I am wondering if/how there is an easy way to keep my existing column (shifter removed) since it's integrated with the steering lock, ignition lock etc.
SS_Malibu
968
1,586
Mesa, AZ
This is the second Malibu I've switched from column to floor shift. I just removed all the linkage, left the column in park and everything has always worked fine. I moved the reverse lights to the floor shifter and didn't worry about the neutral safety switch. However, I am the only one that drives my car.
pagrunt
8,751
14,381
Elderton, Pa
If you just want the look of a floor shift with out buying one just grind down the shifter mounting ears, plug the openning, use some body filler to smooth it out.
Baker7888
567
97
Maine
If column is in park doesnt it lock the steering ??
Baker7888
567
97
Maine
Only if the key is locked. In RUN will unlock the column.
Ok gotcha. So yeah, i have removed all linkages, and the lever. I can put it in park from under the hood where the linkage used to tie to. I should probably rig something up so it stays in park i guess.
pagrunt
8,751
14,381
Elderton, Pa
In my '72 Monte when it was converted to a stick I just let it be. Never moved on me. Even when my '81 was first converted to a stick I used a floor shift column & it's shift bowl never moved either. Nothing was ever used to keep them from moving.
airboatgreg
2,836
3,060
Don't forget when you convert to adjust the flux capacitor at the bottom of the column to the left the adjust for the shifter being farther right.
SS_Malibu
968
1,586
Mesa, AZ
Same here. It's never moved on me. Also, you can put it in park by grabbing the shift bowl on the column where the shifter used to be. You don't need to go under the hood at the linkage location to put it in park.
