Comp cams mix match roller rockers???'#
dickeymoore
924
Atlanta,Georgia
I have comp cams roller rockers part# 1301 and have misplaced 4 of them and comp cams told me to use the part numbers 1601 for replacements because the 1301 rockers are discontinued will it be ok to run mismatched roller rockers
lilbowtie
3,460
3,965
Canton Mi
First of all find them !! Yea it will work those are replacements. Try an RR468#
  • In Love
bracketchev1221
1,406
1,644
rr468 is a private seller number for the comp 1301. However there is no issue using a 1601 rocker. If you really want to try something, buy 8 1.6 rockers and make a split set of rockers.
pontiacgp
blank
Mar 31, 2006
29,270
20,391
Kitchener, Ontario
If comp cams gave you a part number for a rocker they say you can use why are you questioning comp cams.....:unsure:
64nailhead
Goat Herder
Dec 1, 2014
5,697
12,185
Upstate NY
I'm just trying to make sure and have anyone ever heard of this THANKS
Heard of losing stuff? Every freakin' day - wtf!!! I can't wait 'til I get old and get CRS
Use the rockers comp recommended and forget about it. Verify correct push rod length and if the same length is required with the new as the old, then it will be fine.
dickeymoore
924
Atlanta,Georgia
i found the ones i need THANKS
86LK
1,965
2,030
as bracketchev1221 said, keep 4 as spares and buy 8 1.6-ratio rockers for the exhaust. practically same price and you'll get better performance I bet (however that also depends on your current cam, heads, etc)
