compressor bolt
84cutspreme
1,143
151
Does anyone happen to know thread size and length for the bolt that holds ac lines onto compressor at the ac manifold? Or have part #?
69hurstolds
8,185
17,560
Parts book shows:
M10 x 1.5 x 35
Would need a lock washer as well.
GM p/n 14056165 superseded to 15726460, and then to 15029243. Discontinued in 2012.
Strange I can't readily find another bolt part number like it since it was a fairly common use bolt back in the day.
  • Informative
69hurstolds
8,185
17,560
Wait....I looked up 85-88 G-body Olds. I see you have a Chebby engine in an 84. I will ASSUME you have a monte carlo hose setup? From what year? I would imagine the bolt size and thread is the same, but the length may be different. Hmmm.
If it's for an 84 Chevy Monte Carlo setup...which cross checking shows the exact same bolt used in 84 Olds application as well...
Strange. No part number available. Size is shown as M10 x 1.5 x 45 which is just a tad longer than the 35mm long bolt. Looking at a difference approx 1-7/16" length for the 35mm bolt to approx 1-3/4" length for the 45mm.
I imagine it has everything to do with the thickness of the mounting flange. I'm not sure though.
Longroof79
Rocket Powered Basset Hound
Oct 14, 2008
12,173
9,769
Gainesville, Fl
Worse case scenario, use a corresponding stud that size, and nut and washer. Less chance of stripping the threads in the aluminum case.
84cutspreme
1,143
151
Thank you very much! it’s serpentine setup from 92 camaro. I seem to have misplaced the original bolt.
