compressor clutch wiring
UBOWL
11
i have an 88 SS and trying to get the ac working, new compressor new drier and condenser however i can't find the compressor clutch relay or the single wire that runs to the clutch it's nowhere to be found. Dealer installed system. a little help would be greatly appreciated. Thanks John
78Delta88
437
SW Arizona
Did you get answered or figured out ?
Worse case scenario you might just have to wire up yourself. Use the Blazer Fog Lamp relay, or any relay if you have to. I like using the Fog Lamp relay, because it's designed for 30 amp continuous operation. Relays all look pretty much the same, but many are just switching relays and can't maintain long duration continuous operations.
