MONTE CARLO Condenser Brackets
W
Weldingiron
n00b
Aug 25, 2019
Good Evening All!
I recently purchased an AC upgrade kit from Original Air and attempted to begin the install today. I quickly hit a wall as I realized that the upper mounts for the condenser must have been removed years ago with the rest of the AC components. Apparently the part (GM Part Number 467321) has been discontinued and locating an aftermarket source is proving difficult. I am planning on fabricating one for it but am looking for direction. As you can see in the picture there are plenty of holes along the sides and top to secure it, but the factory brackets have rubber on them, I assume to dampen vibration. The bottom rubber pieces are still in place, so should it be sufficient to secure it with metal brackets or do I need to incorporate rubber into the upper mounts as well? Thanks in advance!
Todd
565bbchevy
565bbchevy
7,178
Michigan
Maybe post here in the wanted section, since plenty of people rip out the ac case and put a plate there they would probably have no use for condenser mounts either.
W
Weldingiron
n00b
Aug 25, 2019
I appreciate you breaking your rule; I'll work on that post count! I couldn't bring myself to pay that kind of money with them being used so decided to check out the local junkyard and was lucky enough to find some for a little of nothing.
Reactions: 69hurstolds
69hurstolds
69hurstolds
3,385
Well, that's because it was the only listing on ebay AND the most damning part was the fact that they came out of a GN or Turbo Regal or some crap like that, so the owner immediately thought they were made out of gold poop. When in reality they were only used in about 40 million other G-bodies.
Tip- the newer cross flow condensers are thinner in that clamping region due to their manufacturing dimensions. So if you have a newer condenser and not OEM, you may need to adjust the spread of the clamps.
