Confused, different orifice tube for R134 ???
HAFROD
2,179
3,331
Claremore, OKLAHOMA
So I have read some threads but basically confused now. Is there a different orifice tube that I will need to use with R134 refrigerant? EVERYTHING including evap will be new except the small aluminum line. Was going to start bolting on new stuff next weekend but have to get the parts ordered at my local O'Reilley Auto. The new evaporator is already in my restored heat/ac box on firewall.
84camino
13
2
I'm using a variable oriface tube on my el Camino it moves with the freon flow bought it from rock auto
81cutlass
4,645
13,561
Western MN
I think the red tube out of a 92 or whatever the first years of F150s to have 134 is the cheap right one way to do it.
Honestly, I have a stock r12 orphice tube in mine (actually r12 parts in everything minus new rubber lines and a new reciever drier) and it will freeze up the condenser.
565bbchevy
9,611
12,668
Michigan
So which variable orifice tube do we need for our cars and a part number would be great? I want to get my 86' Regal AC working with all new parts
84camino
13
2
I bought mine off rock auto 3 years ago I'll have to look it up in my files
WordMan
12
2
Lenoir City, Tennessee
You need to adjust the cycle switch up a bit.
Longroof79
Rocket Powered Basset Hound
Oct 14, 2008
12,174
9,776
Gainesville, Fl
Here's the one that I initially installed, but there was a problem with it freezing up and not blowing cold. https://www.rockauto.com/en/moreinfo.php?pk=668605&cc=1055461&jsn=436&jsn=436
The mechanic ended up removing the red tube and putting the standard white orifice tube in and it works fine.
I thought the orifice tube that I first selected would have worked fine. It did indicate that it was for up to 105 degrees...or 105- . Some of the other tubes indicated 105+ for extreme weather conditions.
It just didn't work in my situation.
liquidh8
I have used the adjustable for years, can't remember the part number off hand though.
84camino
13
2
I know mine is white not red just an FYI....I did not find the paperwork yet as its been so many years ago...
