Coolant leaking from weep hole but water pump shaft is dry
Steve Bakken
Feb 20, 2015
83
8
I was always under the understanding that it came out from the shaft when the pump started going out. Any ideas?
565bbchevy
9,591
12,612
Michigan
I know on a Chevy it comes out of the weep hole underneath when the pump or seal is bad.
565bbchevy
9,591
12,612
Michigan
On the other hand coolant could come out from around the shaft if you ignore warning signs like your water pump bearings squealing for their life.
