Coolant Pressure Gauge
pontiacgp
blank
Mar 31, 2006
29,270
20,391
Kitchener, Ontario
Anyone here using a coolant pressure gauge.I have been trying to find a good gauge to buy but I can't find a kit that has a 20-25 lbs max. I can use an oil or gas pressure gauge but I'd rather have a temp pressure gauge.... :popcorn:
Scoot-71
102
157
Rio WI
why
UC645
1,080
3,061
Kittanning, Pa
Would a water pressure gauge work? AutoMeter makes one that goes to 60 psi, there’s others that go higher, but they’re not cheap.
Like $200 not cheap.
DSPbuilt
568
1,542
Cape Coral, FL
pretty pricey but goes upto 100 PSi.
We use them to data log quite a bit. Know if lift a head and prevent possible catastrophic failures.
pontiacgp
blank
Mar 31, 2006
29,270
20,391
Kitchener, Ontario
I saw that one, it is pricey with a price tag in Canada of over $250....:unsure:
UC645
1,080
3,061
Kittanning, Pa
that's strange, I looks at AutoMeter gauges yesterday and never saw this one
https://www.amazon.ca/dp/B00062ZVDS/?tag=rippca-20
This might be what you’re looking for
https://www.amazon.com/dp/B004LE6E60/?tag=gbody-20
It looks like all the cheaper gauges are mechanical though. The ones that use a sensor go for around $200 in the states, I can’t imagine the markup you’ll have.
Here’s one of the electrical ones from Summit
QuickCar also makes one, but I can’t comment on how well it works.
pontiacgp
blank
Mar 31, 2006
29,270
20,391
Kitchener, Ontario
I like mechanical guages, my oil and temp gauges are mechanical. I have Autometer gauges now but they have a black face and I just need it the 35 lbs gauge. The Nascar model is black but that goes up to 100 lbs and it'll cost me over $250
Oct 14, 2008
8,819
7,766
Melville,Saskatchewan
Interesting, never knew they made these but yeah another tool in maximizing your cooling system. Hopefully Amazon actually has these in stock. I ordered two different Autometer tachs, said they were in stock. Waited over a week while they were preparing shipment for the first one. They actually refunded the money it took so long. Ordered another one, same BS message and cancelled it four days later. It they send a message preparing it for shipment, it might eventually show up.
  • Sad
