Cooling Fans
pontiacgp
blank
Mar 31, 2006
29,270
20,391
Kitchener, Ontario
Topic seems to always come up so what set up do you guys use and what have you used in the past and how well do they work. For the electric fan set up what do you use to trigger the fan or fans and what temperature do you have the fan or fans coming on.....:popcorn:
454GrandPrix
429
818
Lehi, Utah
... which means a simple search ought to produce numerous threads and answers to your questions. ;)
At first, I had a (single) Taurus junkyard fan. It was mounted at the driver's edge of the radiator in order to clear the crank snout. My aftermarket external trans fluid cooler was mounted (in front of) the other end of the radiator, which meant the Taurus fan wouldn't really pull any air through that cooler... so I removed the Taurus fan and replaced it with a dual fan setup from a junkyard Chrysler 300M. This now gives me full-width coverage across the entire radiator.
My electric fan has always been operated via a junkyard Volvo fan relay (seen in the above photo). Back when I was carbureted, I controlled the relay via a toggle switch on the dash. Later when I upgraded to FiTech EFI, I decided to let the computer activate the relay. I currently have the fans come on at 205^ and turn off at 195^ (I have a 180^ thermostat in the engine). I never did remove my toggle switch, so I can still override the computer and turn the fans on whenever I like.
-83MONTESS-
4,570
967
Bellevue, Ohio
I'm using a Derale setup that came with the shroud. And for the controller I'm using a $45 Davies-Craig relay setup. Best relay setup I've come across and super cheap compared to most. They're an Australian company mostly dealing with boats.
I went through 3 different controllers from bigger brands before settling on this one that works better and is literally half the price.
I did however modify the sender to go into the water jacket instead of just sitting in the radiator fins.
I can't find any good pics of the setup but I can get some later tonight when I'm home.
Reactions: 4 users
Dayzedandkonfuzed
971
1,268
Anglemont, BC
When I used electric fans i would use the painless 20110 (or 20111, never remember which one's 180*.) HOWEVER, I would use this on the GROUND side of the fan relay, terminal 85 or 86, then ground the other side. This way you dont have 25+ amps going through it.
I run a heavy duty clutch fan on everything now, with a shroud of course, it's not just there to save your fingers. Both the malibu and the cutlass rarely touch 200*, the malibu runs at 160 with a 160 thermostat, even in traffic
454GrandPrix
429
818
Lehi, Utah
Purely out of curiosity, I went Googling to learn more about this. It looks really slick. (y)
-83MONTESS-
4,570
967
Bellevue, Ohio
It's great. Has a digital read out of temp and has a little button on it to set turn on temp. Can't beat it for the price. I used compression style fittings to fit the temp probe into a fitting for the cylinder head instead of pushing it through the radiator.
roger1
537
767
San Angelo, TX
Three row Champion with dual Spal fans. Running a Dakota PAC2750 controller and 3 relays for 2-speed operation.
160 thermostat, low speed starts at 180, high speed at 190.
A/C trinary switch is also wired into the PAC2750 and will kick the fans onto high when the A/C high side pressure determines more air flow is needed.
8,819
7,766
Melville,Saskatchewan
Where did you find it for $40? There site is $73 US, 1 million Canadian😉. The screw in probe adapter is $50+ alone. Still it looks like a very nice set up. I assume their thermal sensors actually last?
Oct 14, 2008
8,819
7,766
Multiple controller failures, relays and thermal sensors have been the trademark of running electric fans. The Stratus/Breeze fans themselves have been great and move a lot of air.
