This is why increasing mass flow rate helps immensely when things start heating up. It's mathematically proven as
Clone TIE Pilot pointed out. It's a closed system so if you you're a believer that slowing down the coolant in the radiator gives it more time to give up its heat, you also must slow down the coolant in the engine at the same rate so it picks up more heat. Meaning that you're losing the war against overheating.
The components also need to be sized appropriately to ensure that the heat rejection by the radiator is at least capable of keeping up with the heat picked up by the coolant from the engine. Also, materials and configuration make a difference. This is why a 3-row aluminum radiator can be just as efficient or even better than an old-school 4 row brass one. Or a better flow water pump impeller is optimal to a cheese-ball water pump impeller.
Thermostats only make the engine heat up to operating range faster. Once opened, the engine is going to rely on the coolant flowing to the radiator and back to regulate temperature along with a fan clutch or temperature operated electric fans, if so equipped. 180 is considered to be a good T-stat opening setpoint for old-school non-CCC engines. OEM's liked 195 because it ensured your engine is totally warmed up and clearances are spec'd right, etc., etc., and good for emissions. Keep in mind some of the sensors may come into play at certain water temps and IIRC, things like the ECM need to know what you're engine coolant temps are before they even start working correctly. So if you have your CCC system still on the car and working, it's advisable to retain the 195 thermostat.
All that said, 160 thermostats are a waste of time on a street engine.
