motorheadmike
8,976
27,522
Saskatchewan, Truckistan
I wouldn't put the rear in yet, unless I missed something..Maybe a test fit, but it'll just be in the way.
I meant that I can put it back and drive it for a whole summer if needed. I still have to finish the notch and do the wheel tubs.
The hole punch works mint! It even flanges 20 gauge well.
motorheadmike
8,976
27,522
Not a huge amount of ground gained today.
However, I did tackle those cosmetic deficiencies of tying the stock shock towers into the frame kick-outs, fixing the knackered shock hole (looked like someone flame cut out a bolt at one time), and boxing in one last piece of the frame inside the torque box.
With that concluded I can either cut the frame notch or start the body work (mini-tubs). I will probably go for the light-duty work for a while.
motorheadmike
8,976
27,522
Cut it; fill later, I say
Le sigh.
Truth is there isn't much to fill. It is going to be a case of: cut, hammer, weld, repeat. Just another hatchet job by yours truly. It can be done with the differential in place - pretty certain I did it that way on the wagon too. Hanging the differential has the added benefit of double checking the 30+ inches I need for tire clearance. Measure twice, cut thrice.
If I need the joy of doing some heavy duty labour I can make the raised spring perches.
Any who... it is still January and the cars won't hit the road until May at the earliest. And even then:
chris farley i got no place else to go GIF
Reactions: 4 users
64nailhead
Goat Herder
Dec 1, 2014
5,660
12,062
Upstate NY
I disagree - drive south and pick up people on the way. In 8-9 hours we can be at Cecil or in Bruce's yard checking out his OTA TV, cookin' weenies and suck down a cold brew or two.
Reactions: 4 users
64nailhead
Goat Herder
Dec 1, 2014
5,660
12,062
Upstate NY
Bruce, did you notice the self invite there?? :0 hehe ( I'll bring you a beer???? )
Texas82GP
Just-a-worm
Apr 3, 2015
7,981
18,676
Spring, Texas
