motorheadmike
8,976
27,522
Saskatchewan, Truckistan
I f*cking despise this Holley pan. But, after many hours of farting around I think I finally solved it.
If you look closely you can see where I had to grind the block... yes, the BLOCK to get the pipe in there. Nothing like laying under the car with metal shavings showering you. FFS, Holley.
The DS motor mount and trans mount had to come apart so that I could jack the engine up and get enough room to screw the fitting into the pan. You can see how there is sufficient clearance between the engine cradle and the fitting when it is set back together.
The pan fitting is half of a male and half of a female 1/2" NPT fitting sectioned and welded together. And then lots of grinding. This was the only way to get the fitting low enough to clear the engine cradle. Nothing off-the-shelf other than a banjo bolt (but, I am pretty sure they don't come with an NPT bolt). The pipe is built out of pipe plug, some 1/2" ID steel pipe, a 1/2" bolt, more pipe, and a -10 AN fitting from Vibrant. The whole idea here was to make it modular for assembly and ease of service. The drain hose will pass through the belt, and as such it needs to be serviceable.
View attachment 104819 View attachment 104820
So there you go. Just to prove it could work I did it... I shouldn't have. But, I did anyway.
Evidently the banjo bolt exists:
http://rover.ebay.com/rover/1/711-5...0001&campid=5335822911&icep_item=382214007714
Texas82GP
Just-a-worm
Apr 3, 2015
7,987
18,693
Spring, Texas
I like Mike's fitting better. Built, not bought.
  • Friendly
motorheadmike
8,976
27,522
Thanks, much appreciated. But - it is nice to see a solution for other folks.
motorheadmike
8,976
27,522
Texas82GP
Just-a-worm
Apr 3, 2015
7,987
18,693
Spring, Texas
motorheadmike
8,976
27,522
Took a bit of time to solve this.
Did some maths, pressed out the cruise control lug, drilled another hole 1.75" through the centre line of the throttle shaft, tapped both holes, and made a simple bracket out of some 3/16" plate aluminum.
Now I just have to put it all back together and sort out the TV cable and throttle cable bracket.
motorheadmike
8,976
27,522
Are you using a TBSS intake? Just finished one up for my build with the Warr 92mm TB. I used a bracket from GlenssAuto
https://www.ebay.ca/itm/TBSS-NNBS-L92-Intake-Manifold-Throttle-Cable-Bracket-WITH-CRUISE/283267499290?ssPageName=STRK:MEBIDX:IT&_trksid=p2057872.m2749.l2649
Nice quality with some adjustability. Just a thought.
Yes, I am running a TBSS intake. That bracket does look nice, but there is no way I am paying $50 for a piece of formed metal (he says having paid stupid money for formed metal pieces on what seems like a weekly basis). The real problem is that there are no provisions for a TV cable... so I will modify what I have on hand to suit. Wait out for more this weekend. ;)
