MONTE CARLO "COPO" Monte Carlo SS - Turbosaurus Build
motorheadmike
motorheadmike
3,339
6,212
Ottawa, Ontario Canada
Work continues.
V-bands on. Turbo leaned back a hair to allow the compressor housing to rotate straight down (going to need to fab a new core support now). Turbo bracing is under way - got to leave room for thermal expansion. Especially since discussing the use of flex couplings with my brother made me leary of blowouts/failure - even with lined ones like I have here.
Welding with the stainless steel 316L wire has been a huge learning experience - takes a lot more amps and wire speed to burn it in. Thus more functional and a few bird-shit welds were made.
20181010_124322-jpg.97325
20181010_154430-jpg.97326
message_1539204472185-jpg.97327
20181010_164925-jpg.97328
motorheadmike
motorheadmike
3,339
6,212
Moar.
message_1539221848779-jpg.97336
20181010_223412-jpg.97337
20181010_223431-jpg.97338
TURNA
TURNA
6,574
8,448
Socialist NY
Oooooooo speed holes!!!!
motorheadmike
motorheadmike
3,339
6,212
motorheadmike
motorheadmike
3,339
6,212
Things are happening.
20181011_142045-jpg.97361
20181011_142108-jpg.97362
20181011_142140-jpg.97363
20181011_142204-jpg.97364
message_1539282824218-jpg.97365
WG is up next.
Turbo Zach
Turbo Zach
1,309
1,996
That is shaping up nicely. Were is the radiator and intercooler going to go?
motorheadmike
motorheadmike
3,339
6,212
Thanks, and I dunno... in the trunk?
Just kidding.
The rad is going to get pushed well forward - likely near where the AC condenser would have been. Maybe past that too.
I am uncertain if there will be an intercooler used in this car down the road - but there won't be one intially (weight savings). Planning to use E85 and meth injection (pre-turbo) to drop/manage the charge temps.
motorheadmike
motorheadmike
3,339
6,212
That's enough for tonight.
20181011_231334_hdr-jpg.97373
This 316L wire really kicks my ass.
S
Steveshow
26
8
Yeah it is pretty good for a factory part. Obnoxiously large - I had to pull the factory driveshaft safety strap to make room for it... and I am going to need to build another loop from scratch.
I still need to change out the rear u-joint as it comes with these from the factory: http://www.dennysdriveshaft.com/p46...universal_joint_3r_series_non_greaseable.html and are not really designed for big power.
I probably have one of these floating around that I can put in the rear position later: http://www.dennysdriveshaft.com/p2154_spicer_5_3147x_3r_series_u_joint._greaseable.html
When I changed the slip yoke I used one of these: http://www.dennysdriveshaft.com/p20...x_combination_u_joint_to_connect_outside.html which is much beefier. The funny thing is that the one I used had to be about 15 years old (been on the shelf forever) - so you know it isn't a piece of off-shore crap. USA! USA! USA!
Did I understand correctly that the aluminum driveshaft is a factory part? If so, can I ask what it came out of?
Similar threads
