MONTE CARLO "COPO" Monte Carlo SS - Turbosaurus Build
pagrunt
pagrunt
3,397
3,705
Shelocta, Pa
Krazy Karpet? Never heard of it.
Nevermind
I had one of those as the last sled up into high school. Made some of the stupid stuff we did more fun. They don't leave a mark when you hit a car. ;)
motorheadmike
motorheadmike
3,380
6,340
Ottawa, Ontario Canada
20190103_210944-jpg.102753
20190103_211023-jpg.102754
motorheadmike
motorheadmike
3,380
6,340
Building things.
20190104_151834-jpg.102803
TURNA
TURNA
6,691
8,629
Socialist NY
Sailboat for the Canadian Navy?
motorheadmike
motorheadmike
3,380
6,340
motorheadmike
motorheadmike
3,380
6,340
Installing things. I shot this through the MCSS grille - that makes me laugh a little.
20190104_182003-jpg.102809
The emergency catch bracket needed some surgery to fit the trans cooler for the transmission I don't even want to use - that annoys me a lot.
motorheadmike
motorheadmike
3,380
6,340
Built a rad "hose" because it is easier than trying to source and remember the weird *ss car you nicked a hose from.
20190105_192608-jpg.102873
And working on the other... gonna put an NPT fitting on top for the steam vent.
20190105_192537-jpg.102874
My welder is almost out of gas. Good thing I work next to an industrial gas supplier. Back to real work on Monday!
motorheadmike
motorheadmike
3,380
6,340
Came inside to relax last night and finalized the plan for wiring this thing. There are somethings about the wagon's LS-swap I am not satisfied with - most notable is all the wiring under the car and along the frame rails. It is very crowded. With this car I want to keep as much as possible inside the cabin. So I ordered up a pair of 22-pin weather pack bulkhead fittings (one front, one rear) so if I need to run a wire from underhood to the rear of the car (ie. fuel pump(s) power or PWM signal) it can go through the car cleanly - no wonky *ss grommets everywhere.
https://www.amazon.com/dp/B00EZSHYVQ/?tag=gbody-20
Relays, fuses, extra connectors and some other bits are coming too. Might relocate the battery to the trunk...
Similar threads
