Core Ground Wire
mikester
2,921
3,683
Small town NY
While I was cleaning my "extra parts" tub out I found a bag labled wagon heater core. Small copper bracket and a thin ground wire. This might have been the original one from the wagon but Ive picked up smuch crap over the past few years I probably just used another one when I reassembled the box.
My question is why is the bracket and core grounded ? I guess I didnt ground the one I have in the box now. The blower motor is grounded already. Will this be an issue ?
blk7gxn
1,390
1,886
  • Winner
Texas82GP
Just-a-worm
Apr 3, 2015
7,987
18,693
Spring, Texas
The bracket wouldn't fit the aftermarket heater core so I left it out. I didn't like doing so and may end up regretting it. I kept it.
fleming442
Captain Tenneal
Dec 26, 2013
13,046
24,216
e·lec·trol·y·sis
/əˌlekˈträləsəs/
noun
  1. 1.
    CHEMISTRY
    chemical decomposition produced by passing an electric current through a liquid or solution containing ions.
pontiacgp
blank
Mar 31, 2006
29,270
20,391
Kitchener, Ontario
your heater core is probably aluminum and the stock is brass so maybe the aftermarket core won't need the strap. If you are concerned you could ground one of the tubes.
Texas82GP
Just-a-worm
Apr 3, 2015
7,987
18,693
Spring, Texas
It is aluminum. I could solder a wire to a tube.🤔
mikester
2,921
3,683
Small town NY
My core is copper/brass. Too late to think about it. I tore into it after I read some of the replies. Screw it. Ive got an extra box seal anyway.
mikester
2,921
3,683
Small town NY
Thats not a big issue.
Im glad I had a new rubber seal for the box though. I tried to split it without damaging it but no such luck. It tore at almost every bolt because I used the black rope sealer in every hole when I was putting it together. I might even buy another full seal kit since the rubber block for the heater core fell apart too.
I guess it was bound to happen. I remember a thread not too long ago about not putting the insulation on the evaporator.. guess thats getting done now too. SMH
69hurstolds
8,195
17,595
Interestingly, according to one viewpoint, ground straps to your heater core is NOT recommended. The first two paragraphs of this article can make you stop and think. I tried to look up whether aluminum or brass was a worse offender for electrolysis when I ran into this point. It kind of makes sense as not all manufacturers ground their heater cores. Apparently, Ford engineers couldn't settle on grounds or not, but eventually not.
It does describe a procedure for checking your coolant voltage, however.
  • Informative
