correct carpet color
Deadeyejedi80
133
144
Saratoga springs ny
Was wondering how i figure out the correct carpet color for my 1980 cutlass supreme? It is the burgundy color but ive seen a couple different options . not sure if its called red or claret or burgundy. Any colors i see online are not very helpful . i would like it to match the rest of the interior as close as possible .thank you
Jeff Blagden
453
654
Winnipeg Manitoba Canada
pretty sure it is claret I have a 1980 salesman dealer brochure at home shows all the options and has samples of the carpet options for all 1980 Olds it is at home and I am at work but will check the book tonight and reconfirm tomorrow thanks and have a good day Jeff from Winnipeg
Deadeyejedi80
133
144
Saratoga springs ny
thank you that would be great
Ribbedroof
4,900
6,993
Wellston, OK
The carpet outfits will send small samples to you at no charge. I pull a sill plate to check for color match. I've learned that when dealing with aftermarket interior stuff, names are meaningless.
