Correct motor to frame mount bracket from 231 buick to chevy 205
Klingerm
n00b
Dec 14, 2020
4
Need to find correct motor brackets to fit clam shell frame moints. I bought aftermarket but are to narrow to fit the clam shell
ck80
2,027
When switching from a buick 231 to a Chevy 305 you need to switch the frame side mount pedestals as well, best bets would be out of a grand prix or monte Carlo that came with a Chevy 305, or, if your in Canada only a cutlass with Chevy 305.
You don't just use the buick frame side mounts on the crossmember and try to piece it together
565bbchevy
8,187
Michigan
These are the frame mounts I used when going from an Olds to a SBC in my Regal but I already had a used set of the upper clamshells for it.
There are aftermarket uppers available but for a 305 swap I would just look for some good used ones but verify the car they came from since there are different height versions.
Reactions: 64nailhead
Similar threads
G-Body Performance Upgrades
