Correct replacement Olds/SBC Radiator
kustomkyle
646
47
Just looking to see if anyone knows where to get a correct replacement V8 OE type radiator for a G-Body?
Basically a radiator with an upper hose port (left), lower hose port (right), transmission cooler ports (right tank), and drain petcock on the very bottom of the right tank.
Everything seems to be the generic type with the petcock on the side of the tank (how does that work?), and an extra port (for a coolant level sensor?) that you clamp a rubber plug over (?).
