corrected Problems with the mini torque starter
84 hennesymonte
33
19
8
hello everybody a couple of months ago i bought a mini torque started and it was sitting on the flywheel once you bolted it up so i took it off and put thre shims on the starter and so far it works well hers a pic!
84 hennesymonte
33
19
8
this is what it looks like when it is bolted up from the top!
565bbchevy
9,614
12,683
Michigan
The main thing with setting up a mini starter is getting it within specs for the distance from gear to the flexplate and also the gear mesh clearance, mine is .030 so I use a piece of .030 mig wire to verify, hopefully you have done this since just shimming can cause other issues later on.
