Corvette wheels
565bbchevy
9,590
12,612
Michigan
Not even close
oldsmobile joe
2,067
3,053
mpls
Nope.
Will need wheel spacers to start, maybe be more.
oldsmobile joe
2,067
3,053
mpls
Maybe.
565bbchevy
9,590
12,612
Michigan
Z06 Front 18”x9.5” (+) 40mm
Rear 19”x12” (+) 59mm
I am still going to say no, unless the plan is to mini tub it and run huge wheel adapters plus a Cutlass has less clearance because of the shape of the wheel well arch and if it is the one in your signature it appears to be lowered only adding to the problem.
Streetbu
Know it all, that doesn't
3,721
11,525
Central NY
Absolutely, 100%, no, not even close. Period.
57 Handyman
338
388
AND, with spacers, that means longer studs are required. Just because the nut will thread onto the stud, don't take chances!
565bbchevy
9,590
12,612
Michigan
It wouldn't be spacers at +40 and +59 mm offset, it would have to be adapters that would only require stock length studs
