coulda been catastrophic failure
Cajun83HO
197
118
Louisiana
UNFORTUNATELY I had to replace the intake gasket on my 83 H/O due to coolant leak. But I am so glad I removed the intake. I found this in #8 intake port. Then i figured out what it was and where it came from. This car has 23000 miles on it, I'm the second owner. The first was a friend of mine. Intake has never been off. Wonder how long it's been sitting on the valve???? Wonder if it has damaged the valve. I never would have found this if it wasn't for the coolant leak. But then again, maybe I would have........
  • Scared
Reactions: 6 users
455'ed80Regal
467
211
Lincoln, MO
GM clearly not thinking when they put those in that intake. I'm like you in wondering if the valve is ok. Could do a leak test on that cylinder to see if there are any problems.
Oct 14, 2008
8,806
7,746
Melville,Saskatchewan
This is where an inspection camera would be good. I am thinking no damage but a compression test should tell a lot.
ssn696
Living in the Past
5,543
6,662
Permanent Temporary
Where was this car hiding with 23,000 miles on it in 30 years? Lucky for you it spent time in hibernation so this problem didn't get worse.
TURNA
Rocket Powered Basset Hound
Jul 24, 2009
10,941
19,990
Socialist NY
its fine. if it wasnt you would have known.
tick tick booooom!
just get some brass plugs and seal up those stupid ports
MrSony
6,790
6,673
Des Moines, Iowa
What are those ports for?
Oct 14, 2008
8,806
7,746
EGR
Clone TIE Pilot
3,827
2,564
Galaxy far far away
Looks like the stud worked loose and fell into that runner. Glad Chevys don't use studs like that.
