What type of setup do you guys run for your crank-case ventilation, and what are your resonings behind it?
For the time being, my engine runs a breather on the passenger side valve cover and a pcv-valve on the driver side, going into a catch can and then into the base of the carburetor.
Trouble is: under light acceleration now, the engine hesitates with a deadspot until I release and accelerate again but harder. When the port at the carburetor base is closed down, the issue is gone, and the engine doesn't suck any extra air. The problem is: no more active ventilation.
My idea now is to just get rid of the breather on the passenger side and keep the rest in place. This should create a good vacuum in the crank-case to suck up any blow-by. Does this make sense, or am I running in the wrong direction here?
