crank question
baddies
21
Would i have any issues using a 556607 maunal cast crank in my 307 even tho is a auto? The only info i can find is that the manual crank has been drilled at the end to support a pilot bearing.
What engine is the crank out of?
baddies said:
All small block Olds cranks (except diesel) will interchange. The balance may be different if the displacement was different, but if you're going from 307 to 307, that's no issue. A crank drilled for a manual trans pilot bearing will work fine with an automatic. The opposite is not true, however.
