Cranks but won't start
G
Geniethechevyg20
n00b
Oct 15, 2018
#1
Hi! I have an 85' Chevy g20 350 motor. I've been having misfiring issues and I brought it in to be looked at and they suggested I change the cap and rotor. Did that it was running a little more smoothly. Was driving around today, parked then went to get gas(got midgrade instead of regular), made another 2 stops. On the way home it stalled out and wouldn't start up again. It's cranking but not turning over. Fuel is good, there is a spark, any idea what else I should check given these issues. Thanks in advance.
pontiacgp
pontiacgp
Canadian Prime Minister
Mar 31, 2006
24,331
9,608
Kitchener, Ontario
#2
what did you check to see if you have spark? Did you try holding you gas pedal down all the way and try to start it?
G
Geniethechevyg20
n00b
Oct 15, 2018
#3
We tested it with the spark test instrument with the light bulb. It's blinking and yes we tried that too. Pulled all the plugs out and there is a lot of fuel squirting out of the 6th cylinder and all the plugs on the passenger side was flooded. Please help.
pontiacgp
pontiacgp
Mar 31, 2006
24,331
9,608
Kitchener, Ontario
#5
I agree it sounds like that the carb is the problem. You don't have the CCC system do you?
G
Geniethechevyg20
n00b
Oct 15, 2018
#6
Sounds like the float is stuck in the carb. Did you put new plugs in after it flooded?
Cleaned them. Still flooding. The spark is a yellow color.
fleming442
fleming442
5,526
6,150
pontiacgp
pontiacgp
Mar 31, 2006
24,331
9,608
Kitchener, Ontario
#8
remove the fuel line from the carb, plug it, hold your foot to the floor until the car starts and let it run till the fuel bowl is empty. first time the car stalls start it up again and again till the bowl is completely empty and it won't start. Then recconnect the fuel line and try to start it normally. If there was dirt on the needle running the bowl empty will sometimes remove whatever was interfering with the needle
Similar threads
