Craziest "fixes" found in your gbody
RabbitHoleSS
712
2,105
Indianapolis
I was welding a patch in my floor this afternoon when I noticed this.
That is the pedal end of throttle cable 😲 I assume it was to hold the pedal to the cable. They couldn't be bothered with cutting the tail off the zip tie either. I was just curious what others have found.
  • Wow
Local Hero
729
1,916
Northcoast, Cleveland, Ohio
Radiator zip-tied to the core support
With the install of a SBC in place of the blown up original Buick V6, the genius ran a fuel line extension from the driver's side frame rail all the way over to the passenger side fuel pump, out of rubber, zip-tied to the front sway bar
Torque convertor inspection cover was missing
Speedometer cable disconnected because it interfered with his hack attempt at installing a floor shifter.
Bucket seats bolted in only on the outer edges where the original bench seat used to reside
Exhaust system was the very last thing installed because it interfered with EVERYTHING Starter was trapped, X-pipe trapped the driveshaft and it quickly became a nightmare trying to drop the trans when the junkyard case cracked in half
And that's just what I can remember off the top of my head since I've been trying to remove it frm my consciousness.
spidereyes455
776
1,614
Northeastern PA
I knew a guy once who would use blocks of wood for inner seat track risers and then would use either really long 1/4" bolts or drywall screws to attach it all to the floor.
  • Scared
08Malibu
1,447
3,385
North Jersey
The olds I bought had the headlights wired to a separate toggle switch with wire nuts on the splices. Of course they were almost falling off with the splice ready to ground out on the shifter.
  • Wow
Clone TIE Pilot
3,827
2,565
Galaxy far far away
On my Regal, somebody used a jar lid to replace the coolant overflow tank cap. Got a proper replacement cap from the junkyard.
Dayzedandkonfuzed
971
1,268
Anglemont, BC
Torque arm on a 700r4 in an f-body fastened to the trans with redi-rod
Drywall mud and chicken-wire to patch a hole in a quarter panel that really needed a patch welded in.
Compression fittings on brake lines (Cue safety debate)
Front wheel bearing lock nut on a sidekick set up like a non-driven wheel (tighten, then back off to first cotter pin hole.) supposed to be torqued to 185ft/lbs
Just off the top of my head....
pagrunt
9,122
15,255
Elderton, Pa
This was post ownership when I had to share it with my brother in H.S., custom stereo work done by him with ALL splices done with the cheapest duct tape he could find. Had no idea of his "skills" until I decided to put a better radio in than his (1991) $9.99 radio.
79 USA 1
1,061
2,031
Cheektowaga, New York
Not on my G body but on a 68 Chrysler Newport I was looking to buy as a beater. Front wheel bearing castle nuts held in with two finishing nails rather than cotter pins. The outer bearing race on the outside right front of same said car had a hose band clamp cut to shim up an incorrect front wheel bearing cup. Passed on that car real fast.
Ribbedroof
4,861
6,888
Wellston, OK
There have been many, but the scariest one was a Bonneville wagon I bought. Had new brakes on it. including rotor on one side. Made a horrible grinding on the test drive. Bought it on the condition that he delivered it to my work about 5 miles away. Got it and pulled the wheel. it had new pads and rotor. It also had no bearing or grease seal on the inner. Had to scrounge a spindle from a friend and fixed it.
I wouldn't have believed it if I hadn't seen it with my own eyes.
Worst part was, guy was a "mechanic" at a local motorcycle shop!
  • Wow
