Crossmember
Codyccg
24
15
Flint,mi
Might be a dumb question but will I be able to install the motor and trans with the crossmember in or should I wait
Scoot-71
102
157
Rio WI
i do believe it will fit, might be a little struggle tho
565bbchevy
9,609
12,663
Michigan
I used to do it all the time but having a tool something like this makes it easier to get the exact angle you need.
ssn696
Living in the Past
5,546
6,671
Permanent Temporary
Crossmember out. If the motor and trans are put in assembled, the tail housing will touch the floor in order the get the bell housing under the firewall. If you install the engine and transmission separately, you need the space to slide transmission up and into place.
64nailhead
Goat Herder
Dec 1, 2014
5,692
12,154
Upstate NY
Not to sound sarcastic - it's 4 bolts dude - take it out. Then you have lots of room.
