Cruise Control Replacement Unit.
565bbchevy
565bbchevy
6,035
5,036
Michigan
#1
Has anyone seen any aftermarket cruise control units that would be a "plug and play" that can replace the bulky factory vacuum control going to the carb.
I don't really use cruise control but it would be a nice option to retain for my Regal if I can but the factory piece just plain ugly.
GuysMonteSS
GuysMonteSS
996
648
Kentville,Nova Scotia,Canada
#2
TURNA
TURNA
7,010
9,247
Socialist NY
#3
I think the 92ish Park Aves are a direct fit
xitabl442
xitabl442
I’ll be following this, I’m wanting to do the same.
I’ve used Rostra in the past, they make good stuff.
TURNA
TURNA
7,010
9,247
Socialist NY
#5
Actually it is a 1992-1999 Bonneville that will bolt up brackets and all
565bbchevy
565bbchevy
6,035
5,036
Michigan
#6
I looked up pictures but can't tell without side by side pictures but is it smaller than the Gbody unit?
Ribbedroof
Ribbedroof
2,624
2,296
Wellston, OK
#7
That Rostra kit looks a lot like the cruise I pulled out of my Roadmaster LT1 donor, I planned to adapt it to the wagon, as it appeared to be fairly simple on an ECM equipped powertrain.
Longroof79
Longroof79
9,838
5,534
Gainesville, Fl
#8
I'd also be interested in putting cruise back in the car. It originally had the old antiquated unit with a bracket mounted servo and transducer. If someone could post a pic of the newer style units, that would be much appreciated.
TURNA
TURNA
7,010
9,247
Socialist NY
#9
78ekly over at MslibuRacing did it
Wageslave
Wageslave
837
900
The best part of the Bonneville servo is that it is set up to be remote mounted, with a cable that runs to the carb. It plugs right in, but can me moved to a more visually appealing area (such as under the brake booster).
Similar threads
contact Admin[email protected] for info on becoming a sponsor
