Cruise Control Replacement Unit.
9,611
12,666
Has anyone seen any aftermarket cruise control units that would be a "plug and play" that can replace the bulky factory vacuum control going to the carb.
I don't really use cruise control but it would be a nice option to retain for my Regal if I can but the factory piece just plain ugly.
GuysMonteSS
1,449
1,541
Kentville,Nova Scotia,Canada
19,992
I think the 92ish Park Aves are a direct fit
I’ll be following this, I’m wanting to do the same.
I’ve used Rostra in the past, they make good stuff.
19,992
Actually it is a 1992-1999 Bonneville that will bolt up brackets and all
9,611
12,666
I looked up pictures but can't tell without side by side pictures but is it smaller than the Gbody unit?
Ribbedroof
4,891
6,931
Wellston, OK
That Rostra kit looks a lot like the cruise I pulled out of my Roadmaster LT1 donor, I planned to adapt it to the wagon, as it appeared to be fairly simple on an ECM equipped powertrain.
12,174
9,774
I'd also be interested in putting cruise back in the car. It originally had the old antiquated unit with a bracket mounted servo and transducer. If someone could post a pic of the newer style units, that would be much appreciated.
19,992
78ekly over at MslibuRacing did it
Wageslave
1,749
3,338
The best part of the Bonneville servo is that it is set up to be remote mounted, with a cable that runs to the carb. It plugs right in, but can me moved to a more visually appealing area (such as under the brake booster).
