Extend the blue, gray, and gray/black from the PCM to the steering column. Cut the car side of the stalk plug where you can splice it, and provide 12 ign to the 4th wire (yellow?). It's pretty easy.
Thx.I guess so. Purple/white is probably VSS. Mine was DBW, so must be different.
https://ls1tech.com/forums/conversi...t-gm-cruise-control-your-cable-driven-tb.html
Ok thanks.I guess so. Purple/white is probably VSS. Mine was DBW, so must be different.
FYIOk thanks.
I really read through that and I have it all wired up now.
Thanks for your input again.
