Custom driveshafts?
Reddzedd
21
4
As I've recently stated in a previous post, I'm 99% sure I'm going to go with this Ford 9" swap kit from QP, with a few of their upgrades.
After some searching around about it, I've realized that I'm going to need to direct some attention to the driveshaft for this rear end to work.
To those of you who have bought this kit, what exactly did you need to do in terms of driveshaft? Did you shorten it, get an entirely new custom driveshaft? Or did it bolt right up?
If anyone was wondering, my wagon came with a TH350 and I plan on getting it rebuilt, so the transmission will remain in the stock position.
565bbchevy
9,590
12,612
Michigan
I had a new driveshaft made by DTS locally when I swapped to my Moser 9" IMO I wouldn't waste time or money on a stock driveshaft that was never designed for the power you want to send to your new rearend.
fleming442
Captain Tenneal
Dec 26, 2013
13,046
24,214
I don't see in the listing, but the standard yoke on a 9" is a 1350 joint which would be a good time to upgrade the front yoke and have a driveshaft built. Try your local truck shop; Fleet Pride have done mine the last few times around.
lilbowtie
3,460
3,965
Canton Mi
Pay attention to driveshaft critical rpm.
Critical Speed Chart
speed-chart
Critical Speed is the RPM at which the driveshaft is computer projected to bend or whip. Exceeding Critical Speed can produce vibrations that can result in driveshaft failure.
The vibrations can also cause damage to the differential gears and bearings. The transmission extension housing, along with the torque converter and planetary gears can also be destroyed.
When you take a small piece of steel and bend it repeatedly, the stress will eventually break the steel. The same effect occurs on your complete drive line when no attention is paid to Critical Speed.
MC96
458
492
For what the local driveshaft places charge surely fast shafts / pst / qa1 etc have an "on the shelf" unit ready to go.
Reddzedd
21
4
Has anyone done a build similar to mine and happen to have measurements that I can use? It would be nice to have measurements done so I can order a driveshaft and rear end at the same time, as opposed to having the rear end sit in the wagon while I wait for a new driveshaft to get here.
565bbchevy
9,590
12,612
Michigan
You need to measure to verify length, that way it eliminates any possible variables.
Reactions: 4 users
bracketchev1221
1,386
1,599
Like was said, its worth taking your own measurements. Ride height, yoke length can all make your driveshaft just a little different. Its better to do it once than have to do it again. I know. I had to shorten a 4" aluminum mark Williams driveshaft for my Chevelle 1". Cost me $500 to have it made. $300 to cut 1" off.
Texas82GP
Just-a-worm
Apr 3, 2015
7,981
18,676
Spring, Texas
For what it's worth, we've used Denny's on three projects and are very happy with the results. They are out of Buffalo, NY. Great people. I've spoken to Denny himself a couple of times. They always have a back log so they aren't the fastest and certainly aren't the cheapest but they are very professional and the quality is outstanding.
