Can anyone post pictures of custom door panels in their cars ? I need ideas for my front door panels.
I did this custom work to the bench seat myself.
Same technique can be used on door panels
Do you have a step by step for that? lol
Didn't I see your work On Will Castros Unique Whips? Or was it his Uniqe Rides? I know thats his kind of custom.I did this custom work to the bench seat myself.
That's nicely done lolI did this custom work to the bench seat myself.
I stripped the original panel down to the hardboard then glued a layer of felt over the complete panel.That looks good is that glued over carved fome?
That looks really good I like the cage toI stripped the original panel down to the hardboard then glued a layer of felt over the complete panel.
I used 1/4" thick hard foam and made my design from that and then glued that onto the felt and then I carefully glued the material over everything and used a roller to help get the edges sharp.
Time consuming but I wanted my speaker up high so I came up with this.
You can see the rear one matches also.
