MONTE CARLO Custom Trunk
rmorman
158
Perry, IA
Greetings!
Recently I switched out my 20 year old 12" MTX sub with 2 x 8in JL Audio suns in a box that tuck REALLY nicely up against the back of the rear seat in the trunk. I think I FINALLY need to address the trunk carpeting. Since I posted last on this, many of you have posted showing your custom trunks. I'm ESPECIALLY interested in those with "compartments" on the left and right sides for storage of cleaning and dusting supplies.
Most importantly, how much carpeting did you order? I'm just looking for black. Specific width/length? Amazon?
Pointers from those of you who have created the storage areas or other custom things in your trunk?
I had Also given thought to modifying one of the kits from Dixie Restoration or GBody parts.
My plan was to make templates from sheets of cardboard and then cut up some old corrugated chloroplast signs that my work had old advertising on and attach the carpet.
Thanks,
Russ
rmorman
158
Perry, IA
1/8 or 1/4 Masonite will be stronger than corrugated plastic.
Don't put any screws through the top of the gas tank!
Good call on the Masonite. Betting it does not weigh all the much either. That would be perfect for the storage areas. Yea, I'll be mindful of the tank! LOL!
RICKDIZZLE
249
215
Yes for sure use Masonite. I used it in my set up and came out great! I got a roll of carpet brand named "Install Bay" from Amazon. Its not world class carpet but seems to hold up well. It came as 5 yards and did my entire trunk. The only thing I don't like is the Masonite is a tad to thin on the beauty board peices I did around my subs. I am going to go with MDF when I hardline my hydraulic output hoses. For my panels, I just used poster board to make templates, once I had them all done and they fit together, I transferred everything to the Masonite and then used a jig saw. Test fit everything again then used 3M Super 77 spray adhesive. Wrapped everything and popped it in. Not a high end trunk in the world of lowriding...but considering I did everything myself I am happy with the results. Gets a lot of compliments at shows as well. Here are a few pics. Hope this helps!
  • Love
rmorman
158
Perry, IA
That looks pretty good. Did you glue the piece on that goes around the trunk latch and tail light bolts? It looks great. Did it lay down pretty easily and conform to the shape?
Also, how did you attach the Masonite on the left and right panels? Did you screw it to the bracing?
Thanks!
Russ
fleming442
Captain Tenneal
Dec 26, 2013
13,046
24,216
Trunk liner carpet is generally pretty stiff, so does not conform to too much easily. However, it easy and somewhat forgiving to butt edges together. Glue it, lay it down from the highest or lowest point, work out to the edge making small pleats, tighten the pleats as much as you can get, then trim them off with a razor or shears.
rmorman
158
Perry, IA
Sounds doable. Thanks!
RICKDIZZLE
249
215
The carpet I used is designed for speaker box enclosures and such. It doesn't have a super thick backing. Yes I glued the carpet around the trunk latch and the tail light bolts. I basically installed it anywhere you could see. I did as fleming442 said. Started at the middle on that panel and worked my way to the outside. Everything is pressure fit. Meaning nothing is screwed in. I carpeted the face of the rear deck then the panel where the latch and tail light screws are first. Then the trunk floor peices went in, then the side pieces. Lastly I installed my sub box and then the beauty boards around it. Literally all pressure fit together. And even with use of my hydros...hopping, side to side and three wheeling...nothing shifts moves...nada. If you want to anchor them. Use interior push clips like for door panels. Drill the holes and install the clips then wrap your piece...then you can push them into place and not have a visible anchor point.
rmorman
158
Perry, IA
Thanks! I want to make the panels on the sides to be accessible for my California Duster and other supplies. Maybe a hinged door or something. I've seen some online that look nice.
