Cutlass Cruiser resurrection ~ Single Turbo + 4.8L
mclellan83
4,204
9,310
Pgh, PA
Good to see the knowledable guys have already chimed in, I will say I want to see how it all comes together
Nutty Cutty
Apr 30, 2019
66
I got an issue guys. Maybe someone can help me. I bought the cheap converter spacer to mate the th350 to my LS but there's a big gap between the flex plate and the conference bolt pads. I don't want to destroy the trans pump.
Should I swap to the crank style spacer instead and does this go between flex plate and stall? See pic below
Injectedcutty
G body LS mafia
Nov 24, 2014
6,057
22,807
Louisville, KY
Should I swap to the crank style spacer instead and does this go between the crank and flex plate this eliminating the need for the other spacer? See pics below
Buy once, cry once. I completely understand trying to save a few bucks here and there, but it'll usually end up costing you more down the road.
Nutty Cutty
Apr 30, 2019
66
I guess I need to add some info. I was typing on my phone earlier.
With the converter snout spacer on the converter the snout does not bottom out in the spacer. I think it could be too long which would cause more space between the stall and flex plate. I will trim it down. I just didn't want to end up wiping out the thrust bearing in the motor if I have too much spacing and the stall is bottomed out in the trans pump.
81cutlass
4,639
13,542
Western MN
The turbo needs a Caterpillar sticker on it
Nutty Cutty
Apr 30, 2019
66
Yeah the idea was for it to be Gold. The powder coat I did is nice but I'm not crazy about the color overall. I may do it something bright and colorful. Neon something
