Cutlass rally gauge problem...
Gozer442
281
259
Ontario, Canada
I have a rally gauge cluster with just the oil, water, volt, and fuel level not working. What's the common wire/fuse/ground for those 4 gauges in the cluster? The idiot lights, speedo, tach, and indicators all work just fine.
I'd figure I would ask first, before ripping things apart.
Thanks guys.
Gozer442
281
259
Ontario, Canada
No, I don't have a service manual. All the connectors are new to the sending units. The gauges were working when I had it out last Friday. Just seeing if anyone had the same experience before pulling the dash out.
pontiacgp
blank
Mar 31, 2006
29,270
20,391
Kitchener, Ontario
the fuse for the gauges is a 20A on the left
Gozer442
281
259
Ontario, Canada
Thanks pontiacgp.
I just went out for lunch in the Cutlass...all the gauges are working! I didn't touch a thing! What the...
pontiacgp
blank
Mar 31, 2006
29,270
20,391
Kitchener, Ontario
Thanks pontiacgp.
I do not like problems like that, I like to find them and fix them so they don't come back....I hope yours doesn't come back
oxide80
125
64
Maine
I had an 1979 El Camino with rally gauges that did the same thing, problem was connection between the wiring harness and the dash custer. Cleaned connections and it worked betterm but not 100%
Gozer442
281
259
Ontario, Canada
Thanks guys. I'll be pulling the cluster out this weekend and having a look. I'll post some pics of what I find.
