WANTED Cutlass T56 trans cross member
Trader history (0)
88 Gutlass
Jan 1, 2020
Ga
Looking for a modified stock or anything that will fit my T56 conversion. Yes I know they sell them new but trying to cut a little cost.
81cutlass
4,309
Western MN
Do you have an existing 2004r xmember?
If you have a grinder, a welder, and some 3/16 plate hanging around you can cut the existing trans mount pad off & make a new one. The T56 is a lot taller in the shifter area than an auto so the trans has to lower some in order to clear the floor pans. I dropped mine about 1.5" and moved it forward
88 Gutlass
Thread starter
Jan 1, 2020
Ga
I ended up just ordering a Evolution Racecraft crossmember, I don’t have the welding skills
ssn696
Living in the Past
5,385
Permanent Temporary
Apologies that it took me a week to dig these out. Heavy 11-gage steel, matches the contour of the stamped GM frame extension. Cut, weld and drill to your custom application. Stiffer than bolting a piece of square tube and cantilevering the trans mount. E196C98F-DE8F-4BC3-8653-6D3F963EEAB8.jpeg
88 Gutlass
Thread starter
Jan 1, 2020
Ga
Apologies that it took me a week to dig these out. Heavy 11-gage steel, matches the contour of the stamped GM frame extension. Cut, weld and drill to your custom application. Stiffer than bolting a piece of square tube and cantilevering the trans mount. View attachment 208019
Well the one I ordered and waited 6 weeks for didn’t fit!!! Guess I will need to try to do this
Classic Truck Consoles Dixie Restoration Depot Mike's Montes UMI Performance
